Dave burke
- Near Lake Placid
- X
After planning for two years and buying most of the equipment over a year ago, I’ve finally started doing the work. And I started off making a dumb mistake. More on this later...
Current stock set up (2017 212X):
- Polk Head unit and wired remote control on swim platform
- 2 Polk db651 speakers in bow
- 2 Polk db651 speakers Mid-cabin
- 2 Polk db521 speakers in swim platform
- WS Stealth 10 soundbar in tower
- Polk sub
- Polk 5000.5 5 channel amp
- bow & mid-cabin speakers wired in series to front channels; swim platform and soundbar in series to rear channels
Planned set up
- run new knukoncept wire to all speakers
- keep all Polk speakers except the sub
- add two db651s to the helm area
- replace sub with JL M10IB5
- add two Polk 4000.4 amps @125w per channel
- add WS420SQ
- move amps under helm and mount on a board like @Mainah and others have done
My questions:
1. I started by cutting holes for the new speakers using a 5” hole saw. Began by drilling a pilot hole and checked depth. Then started the drill in reverse as suggested by @Julian. Port side went just fine but starboard not so much. I ended up cutting two wires, an RCA cable (no big deal since I’m replacing them) and the wire from the HU to the swim platform remote. This was really stupid and I realized in retrospect that had I stuck my nose deep in the helm cabinet, I could have seen that the wires were right up against the backside of the fiberglass.
Question - has anybody tried to splice this wire together? It’s a four pin connector. Or do I have to run a new wire?
2. I’m planning on using one 4000.4 amp for the four cabin speakers, another for the bow speakers and soundbar and two channels from the 5000.5 for the swim platform speakers and sub. I was originally thinking of another set up but then one of the rear channels in the 5000.5 went bad so decided to go this route. I think it’s a better way to go anyway since the 5000.5 is only 70w per channel and the swim platform speakers are smaller and lower rated.
Question - does this make sense? Any better alternatives?
3. I’d like to have four zones (bow, cabin, swim platform and tower) and the WS420 only has three (boat, tower, sub). I’m thinking of connecting the bow speakers to the front channels of the HU, using the “Boat” zone in the WS420 for the cabin speakers and using the “Subwoofer” zone for the swim platform speakers. I have a line level controller for the sub already included with the 5000.5 so not sure I need to run the sub through the WS420.
Question - could this work? Is there a better way? I’ve seen from different posts that others have created four zones but I couldn’t follow how they did it.
4. I was thinking of buying an inexpensive oscilloscope to tune the amps and the WS420. I know @jcyamaharider and others use an SMD DD-1 but I don’t want to spend $150 ideally. The oscilloscope I’m looking at is this one, $42 bucks:
Question - is something this cheap just a waste of money or will it do the job? Any other recommendations?
Thanks as always for any advice. I’ve learned a ton from this forum and will post pictures as I go.
- Polk sub
Planned set up
- add WS420SQ
My questions:
Amazon.com: Quimat Updated 2.4" TFT Digital Oscilloscope Kit with Power Supply and BNC-Clip Cable Probe Q15001 (Assembled Finished Machine): Industrial & Scientific
www.amazon.com
