Fire Extinguisher Location 2020 195S
Charliemck
Where is everyone mounting there fire extinguisher in your 195S? Can you mount horizontally?
Mike Cardillo
Rochester NY
195S
Dealer mounted mine horizontally in bow end of compartment battery is in.
mjs5128
Hatfield, Pa
195S
I was eyeing that location up this afternoon. Did they mount it on the angled area of the fiberglass?
Mike Cardillo
Rochester NY
195S
No, it is on the floor all the way to the right (toward bow). Probably not where I would put it. I'd take a picture but boat is covered. I may eventually move it to the helm compartment.
Jeff L24
195S
I was looking at the same area but wasn't sure what type and size of screw to use. Is it pure fiberglass I'd be screwing into? How thick is it, isn't the fuel tank just below it?
Mike Cardillo
Rochester NY
195S
Right against the right wall of that compartment there is a wedge shape in the floor which is presumably all fiberglass. I had no problem putting screws in there. Probably used about 3/4 inch screw if I recall.
