dan144k
- Palatine, IL
Our family uses the Kodi system everyday. works great and very happy with it.
Hey Mark. That unit you posted is a bit different. The TabloTv seems to only contain HD tv channels that one can pretty much receive if purchasing an HD Antenna. My boxes contain, TV, TV Series, Movies, Movies from the theatre, Porn, also contains TV channels from other countries as well@GeniusGio is this unit complimentary or equivalent to what you are selling, re: android box?
Is running a vpn required/advised?
Running a vpn is always good for this and other things as well, but not necessary. Ive been using my personal box for about 3 years now with no issues what so ever@GeniusGio is this unit complimentary or equivalent to what you are selling, re: android box?
Correct, the TabloTv is just a straight tuner and dvr that you would connect to an HD antenna, then use a Firestick, fire TV, or roku stick to view the content. It will play live tv or record, similar function to a typical cable or sat Dvr.The TabloTv seems to only contain HD tv channels that one can pretty much receive if purchasing an HD Antenna.
Dan - are you still happy with this, any downside you've experienced?@GeniusGio
Thanks for the 2 android box's, and fire box programming. They work awesome. Literally was plug and play like you said. Family is finding so many TV shows and movies it is unbelievable what is available to watch.
Amazing how happy the wife is to find TV shows.
1. What are your internet speeds@GeniusGio I have Pukse up and running on my stick but getting very poor streaming results (too many pauses). Does the Fire TV box perform better due to the Ethernet jack? I can stream via WiFi just fine on a Roku and Apple TV.......just not this Fire Stick.
They took indigo down now. Exodus is also dead. I would suggest using "covenant" now. It's the new Exodus.
