First impression and question on connex
Adubbs76
New Hampshire
Limited
I just splashed my new 2017, 212L. I got a great deal on a leftover model that never sold. A few quick first impressions the low-speed steering is not that bad . The boat scrubs a little more speed when turning than I thought. And it’s also not as loud as I thought it would be .
Now from my questions . Whenever the boat turns on the radio comes on automatically. It’s a little annoying is there a setting to make this not happen? I try to play around with it, but I couldn’t see anything. Also when I press the satellite button it doesn’t stay on satellite it stays on radio the satellite presets flash for about five seconds and then it goes right back to the radio . This weekend is free SiriusXM and I thought any equipped device is supposed to pick up the signal for free until after memorial day. I know in my other devices you can get the set SiriusXM preview Channel and also there’s a number of the radio so you can call and order I can’t find this. Thank you in advance.
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
Your boat is Sirius ready, not Sirius equipped. You would need the car module.
seadude
NJ
In my 2016 version you've got to hunt around to power off the radio before you shut off connext.
Mainah
Chapin, SC
Connext is programmed to default to the radio and the last volume setting. No way to change that. I find it easiest to just turn the volume down before shutting off the boat.
Something that helps a lot is the custom plug and play push button start stop kits that my son makes and that I sell. Allows the keys to stay in the on position but the engines to be shut off leaving the radio on intil you shut of the keys. One quick press of of start button and both engines start sequentially and one quick press of the stop button and both engines stop instantly. Keys are required and all key functions are maintained.
Adubbs76
New Hampshire
Limited
Thanks for the help I guess I will be Bluetoothing it.
GoVols01
College Grove, TN
Managing the radio while tubing is a PITA. Whenever a rider goes down, you need to power off the engines, which cuts off the radio. Then, it all needs to reboot when the engines are turned on again.
I found a remedy for this by doing the following:
Turn engine #1 off, but then turn the ignition back on after the engine died.
Leave ignition from engine #1 on with engine off.
Turn engine #2 off completely.
Allow rider to board the boat/board/tube
Restart engine #2
Restart engine #1
Radio never cuts off and the good times continue to roll!
Mainah
Chapin, SC
Restart engine #2
Restart engine #1
That does work. To be candid if not interested in push button start and and only the stop side a single dpdt momentary button can be installed to accompish that with only 4 wires.
Bennie
Loxley, AL
Restart engine #2
Restart engine #1
I never thought about doing that! Nice find.
I've always just engaged the blower before killing the engines. It keeps all other electronics powered and allows for minimal interuption to the rest of the crew.
