YamaHog
- Little Rock, AR
- Limited S
I'm about to charge the battery on my 2020 195S for the first time and have a simple question. It's been a LONG time since I've operated a boat, and the boat I used to run was a 2-Stroke Outboard. On those boats you had to completely disconnect the battery before charging or you would burn up the the power packs! I read my Yamaha manual and it doesn't say anything about disconnecting the battery from the boat before charging. Is this necessary? What steps should I take when charging? I'm going to be using a new ProMariner HD12 2 bank charger (planning to a.dd a second battery next year when I install tower speakers).
Do I need to turn the battery switch to the off position before charging or anything like that? Maybe I'm missing it somewhere, but I wish the Yamaha manual was more detailed in regards to the battery charging. The ProMariner charger instructions leave a lot to be desired as well. Thanks for any info! I'm taking the boat out for the second trip tomorrow.
