UnfixedPyle
- 212X
Is it normal for the cooling port on the side of the boat to stop outflow of water after a while? I've only had the boat out 3 times and everything looks fine on the water, but when I run the engines at the house with the hose attached the water will flow fine and come out of the port for a while (1-2min) and then stop. Water pressure is the same the whole time. Is there a thermostat that shuts down the flow or do I have an issue?
