CAM212SS
- Knoxville TN
- SS
Kind of hard to see @CAM212SS . If that's the darker area I see near the bottom left and right I think you're probably ok but here's a test. Run @ WOT with the filters in and see if you get max RPM. If not, remove the filters and run at WOT again, see if the RPM's increase. That will tell you if the engine is breathing properly through the filters. You should do this test on the same day. If there is a significant difference in RPM I would go with new reusable air filterswill i need to replace the filter. Some of the fogging oil came back on to the filter. I may have sprayed too much, however the other filter is fine. Spayed same amount in both filtersView attachment 2192
I totally agree and it doesn't look like a big deal to me.Kind of hard to see @CAM212SS . What I would do is run @ WOT with the filters in and see if you get max RPM. If not, remove the filters and run at WOT again, see if the RPM's increase. That will tell you if the engine is breathing properly through the filters. You should do this test on the same day. If there is a significant difference in RPM I would go with the reusable air filters
Just curious @CAM212SS Can you remove the air filter on the 1.8's before fogging? I have to on the MR-1's to get to the intakes but not sure on the process for yours.very good.. i kinda thought that it might not be a huge deal since the oil is sprayed into the intake anyway.
i am getting anxions to get on the water, so i was in the boat this evening tinkering around when i noticed it. great idea @Gym . looking forward to WOT
yes you can. I had read on other posts just to take off the hose between the filter and the intake and spray in that way... it is not too hard. just have to twist it a little at the right angle and it will come off. I will take it off next winterization and fog that wayJust curious @CAM212SS Can you remove the air filter on the 1.8's before fogging? I have to on the MR-1's to get to the intakes but not sure on the process for yours.
