Kevin M
- Streetsboro, Ohio
- Limited S
I typically walk around the boat and do a cursory search/inspection for items as most of us probably do. On Sunday, after a return 200 mile trip home from the Ohio river, I was disconnecting my hitch and I noticed the front/folding part that swivels, was loose! I'm like, what the hell? Closer examination revealed the nut and bolt assembly (bottom one of two) had loosened itself up and was allowing about a 2" up/down play in the hitch. I re secured it but for those with the Shore lander trailer, check it out. Photo of the bolt assembly attached.
