johnso30
- Limited S
In short, is there some way to adjust the friction of the forward/reverse control in the control box, other than the throttle friction screw?
My throttle levers are really hard to move in/out of neutral. I’ve adjusted the throttle friction screws and I can’t loosen them anymore or else the throttle will start slipping and loosing speed while underway.
I assumed that it was probably the cables stiffening up, so I opened up the throttle control box and lubricated the cables. The cables move smoothly when they aren’t connected to the control box, and the reverse gate moves freely as well, so it’s definitely the control box that is the issue.
I looked at the controls some while I had them open and was hoping to see some adjustment similar to the throttle friction screw, but for the forward/reverse part of the control. I didn’t see any adjustment, but thought I would ask to see if I’m just missing it.
