Geiger41
- Egg Harbor Township NJ
- Boatless
- NA
- Other
- NA
So I took off the drainage tray and did a little inspecting. No rusty or loose clamps were observed. A little water was in the very bottom of the area but I guess that is normal. I did see a bunch of plugs connected. There was one plug however that was not connected nor did it have the other wire in the area to connect too. It was labeled "TRI". Not sure what it is for.
I then saw a metal handle that was connected to a bottom brass fitting, not sure what that fitting is and what the handle is for. But it extends up to almost the top of the compartment, gotta be a reason ??
Then I saw the exhaust muffler (I think that's what it is, big silver metal cylinder) was resting on wood. Not sure if that is a good thing or bad thing
I finally sprayed everything down with some CRC, closed up shop and called it a day.
Thoughts ????
Thoughts ????
