FSH 190 Fuses
TommyB
Ocean City, MD
New owner here - so far so good!
Maybe a stupid question, but I am not with my boat right now: Is there a standard fuse kit that any guys would recommend to keep on the boat in the event of a blown fuse?
Thanks in advance
Van T
Chesapeake va
There is a fuse above the cut off switchs hard to see rt under the deck you need that one it pops you don't have working gauges ,bilge pump no lights it will start and run that's it I can't remember if it is a 10 or a 15
Akwoolf
Michigan
FSH Deluxe
Thanks in advance
Recent experience has led me to recommend having a kit such as this on your boat:
https://www.amazon.com/Blade-Fuses-Assortment-220PCS-Standard/dp/B07786GPGK/
Maybe a bit of overkill, but doesn't take up much space. There are also a few spares included in the fuse block. Edit: There is also an ATO-type fuse in the battery box. (20 Amp, if I am not mistaken). There are also fuses under the center console - I don't have the list handy, but I seem to recall that they are lower-amp ATO fuses. The fuse kit will have you covered. (ATO fuses may also be referred to as standard fuses. Essentially the FSH has a mix of standard and mini)
Edited: Added a new link to a fuse kit that includes both the ATO-type and mini fuses. Any kit that includes both types of fuses is helpful.
In case you are curious, I have included a diagram of the fuse block.
Van T
Chesapeake va
There's more fuses than that I'm not sure if those ones are mini fuse's but the one above cut off switchs is ato fuse
