daaaddy27
- FSH Sport
Hi again, I installed my Lectrotabs today with the MLC-1 controller. Got the tabs all setup, drilled out the hole in the dash for the controller, ran the electrical and tried to turn the tabs on ... nothing. The light to the controller doesn't work, and none of the tabs move.
Here's how I ran the electrical, I must have done something wrong and I'm looking for help: I ran the cables from each actuator up to the controller and installed them in the 3, 4, 5, and 6 slots. I ran 14 gauge wire from the 7 slot to a spade connection into the accessory switch. The #2 slot is the ground and I ran 14 gauge wire, and grounded it to a steel bolt in the helm. Finally #1 is the power and I ran that to the house battery where the kill switch is and connected using a battery terminal connector. Installed a 15amp inline fuse for the power cable as well.
Did I do something wrong here or is there something up with my controller? Should the ground be run to the black terminal on the house battery?
