    With a Maximum discount of 35% this is the highest discount you can get on these, so don't miss out!
FSH question ....
yam240sx
accessing the fuel tank on this boat is only a small hatch correct ? what if the tank were to ever leak or need replacing ?
I believe (as I have never actually removed my tank), that the small access hatch behind the helm is just to get to the fuel pump and wiring, but if you have to take the tank out entirely you go inside the helm and unscrew/remove the white starboard material that is at the back/bottom of the helm space and then you pull the tank out from there.
i was looking at one in the dealer 252 fsh and was baffled as i saw no 4 hinges like the Ar sport boat models
