zfire97
- SX
I replaced a Fuel injector in my 2006 SX230 MR1 motor. Now the motor crank immediately runs to 9k RPM. The throttle body is closed. Injectors are firing. I can't connect to the YDS ECU connector squirrels chewed through the wire to on motor. What could be wrong? Is there a way to hook directly to the ECU? to figure out what's wrong?
Thanks
Z
Thanks
Z
