  • Guest, we are pleased to announce that Hydrophase Ridesteady is offering an extra $50 off for JETBOATERS.NET members on any Ridesteady for Yamaha Speed Control system purchased through Sunday, March 9, 2020. Ridesteady is a speed control system (“cruise control”) that uses GPS satellites or engine RPM to keep your boat at the set speed you choose. On twin engine boats, it will also automatically synchronize your engines.
Garbage can in head
AJack
Tampa 33621
Purchased on Amazon for $20, fits perfectly over the bar in the head. 49364763-A1CE-474F-8A35-38E29B68B621.jpeg
BigAbe75
Litchfield, IL
Have you used it on the water yet? Does the whole can come off to change the bag? Does it sit secure enough that there’s no worry of it jumping off the door in chop?
Could probably zip tie the bracket to the rod, but then you couldn’t change the bag, I guess??
I think I’m going to add this to my cart and show it to the admiral. :) thanks!
AJack
Tampa 33621
It was delivered while I was out in the boat today, so I didn’t get to water test it. The bracket is not part of the top, thus you can secure it to the rod and still change bags.
swatski
Saint Louis, MO
Do you think a person could still use a portapotty in there with the trash can mounted? Does it interfere with the toilet paper holder?
TIA
AJack
Tampa 33621
I sat in the compartment with no issues, the TP holder is accessible, but you’d need a small roll. I use the CostCo rolls, which doesn’t fit either way. D4CA8468-E9B2-4B07-A4E8-0B318CE829F7.jpeg
Scuba_ref
Kailua Kona, HI
I read the thread title and my first thought was OUCH!
ralphsmithiii
Tampa, FL
This is gold! Just bought one myself. I was using the rod as a paper towel holder but I've needed a trash can solution more often than paper towels, so far.
Beachbummer
Houston TX
That's a nice set up. I ended up with the garbage can through the cup holder. on the rear starboard instead, with a small 2 gallon mini-pail..
Jmland
Super I was looking for something like this. Thanks .........
