Possibly, I've seen a few that have. Or maybe very close to that locationso you would remove the depth tranducer for the connext?
Pics? And what was the transducer model? This will probably be an off-season thing. I’ve already got too much to do before I get it in the water this year.
I used the garmin GT8HW-IH Chirp Transducer....I thought I took some pictures after I installed it but can't seem to find them. I put it in the flattest spot I could find next to the OEM transducer. Sand down the hull where you put it and sand the transducer and then I used a two part epoxy. I needed an adapter cable to connect this transducer to my 63cv, not sure if you would need one also but may want to call Garmin to confirm which one you need.
Amazon.com: Garmin 010-12401-10 Freshwater GT8HW-IH Chirp Transducer - 250 W, 8-Pin: Automotive
Why not put the regular transducer on the ride plate and run the wire through the transom above the waterline? Others have done this here and it works well, looks clean, and keeps the wiring out of the water.Did you use a 0 degree mounting ring? I am about to mount an in hull transducer to my 74CV, don’t want to drill through hull.
I already bought the in hull transducerWhy not put the regular transducer on the ride plate and run the wire through the transom above the waterline? Others have done this here and it works well, looks clean, and keeps the wiring out of the water.
is that the bracket it came with?Bumping this old thread, so I recently went out with a buddy who had a UHD transducer on his Garmin and the difference was night and day. Needless to say I mounted the same one on the transom. Personally I did not want to make any holes but since we have been getting into fishing lately it was more of a necessity at this point. The thru hull transducer saw "some" stuff but the UHD transducer is night and day. I left the thru hull in, just incase something happens to the other one.... Spent Monday afternoon installing the new UHD transducer- tapped 3 10X24 1" SS screws into the ride plate and also used nylock nuts with a bit of blue locktite, then I ran the wire and filled all holes with 3M 5200, used a blue seas cable clamp up top then filled the hole with 5200 for extra caution..... Last thing I want is any leaks.
