Judge
- Cape Coral, FL
- 275SD
*EDIT* This thread was originally titled 275SD - Garmin ECHOMAP 7" UHD2 74sv with GT54 Transducer Install but as you read through the threads you will see I ended up going with the 9" ECHOMAP UHD2 instead. You will be able to see the pictures of both the 7" and 9" units for comparison purposes if you are trying to decide which one to go with for the 275 helm area.
I'm working on a couple large projects for my '22 275SD over the next three weeks (Lectrotabs, Chartplotter, Battery Upgrade and Solar Charger). I thought I would do a quick write-up on the Garmin ECHOMAP 7" UHD2 74sv with GT54 Transducer install that I in the process of completing in case anyone is interested in adding one to their 275 or similar boat.
Here are the components that I purchased for this project:
1) Garmin ECHOMAP UHD2 74sv with GT54 Transducer (Navionics Coastal): $1049.99 Amazon.com
2) 1.5" ARM / RAM Marine Electronic Mount: $52.99 Amazon.com
3) RAM Mount Base (RAM-202U-152 1.5" X 2" Rectangle Base with 1.5" Ball): $22.99 Amazon.com
4) Garmin Heavy Duty Transom Mount with Spray Shield: $31.25 Amazon.com
5) Garmin 10' Extension Cable, 12-pin: $43.16 Amazon.com
6) Bus Bar Positive and Negative 4 x 5/16” Studs and 4 x #8 Screw Terminals Power Distribution Block: $17.99 Amazon.com
7) SeaChoice 17901 Thru-Hull Fitting: $12.34 Amazon.com
