Jet Boat Okie
- Lake Texoma
- FSH Sport
Here is a post on my setup. This is my second summer and I haven’t had any issues.
Here is a couple of Pics of the dual transducer setup. I can send more of the install if there's interest but I basically used the existing hole location (had to widen it for the Solix connector) on the Starboard side even though it was below the water line. Even though not being symmetric, I opted to locate the Port side side transducer thru hull above the waterline. I used the Humminbird Y cable and it auto detected left and right with no setup required on my part. I may add a thru-hull transducer at a later date as I can add a Y cable to the Transducer Y cable and in theory the head unit should recognize all three. View attachment 186567View attachment 186568
Second pic location is on a the steep edge of a drop off from 15ft down to 40ft and the weedbed on the left at the drop. I was trolling an 8inch Muskie lure basically 15-25ft back as they like to hit lures in the jetwash area at around 3.6-4-1mph.
Here is a how it looks at speed. It was rough on the river, but the scans were pretty clean.I did and it worked really well. Except I was not happy with the lack of rigidity in the mount. Reverse thrust was enough to cause the transducer to rotate down.
So I went with a third iteration. I mounted it to the bottom of the articulating keel with some aluminum angles. I am really happy with this installation. The imaging is very clear. I am not too concerned about hitting anything it only hangs about an inch below the solid keel.
Some time in the future, I will probably switch over to stainless steel angles and trim the bottom of the froward part of the articulating keel to give some room for the wire and get the top of the transducer against the bottom of the articulating keel.
Looks great!I think I have finally arrived on a transducer installation.
I went with dual GT56UHD mounted on the ride plate on either side of the keel.
I tapped the ride plate to accept 10-32 screws.
I am happy with this installation because the side scan has a clear view and the transducers are protected as much as possible from impacts.View attachment 208022View attachment 208023View attachment 208024View attachment 208025
Ohh, i didn't realize you could use dual GT56's. Did you just use the combiner cable and then in software select which was right/left?I think I have finally arrived on a transducer installation.
I bought the Y-Cable (12-pin Transducer Y-cable | Garmin). It is labeled Port & Starboard.Oh, I'm going to
Dang that is a game changer, for some reason I assumed you needed their dual in hull transducer setup to make that work... I'm hoping for boat #2 next year and then this will be the way I do it for sure.I bought the Y-Cable (12-pin Transducer Y-cable | Garmin). It is labeled Port & Starboard.
Everything worked when I connected the plugs.
I finally found a mount location that solved losing sonar at higher speeds (30 mph).
First I found this video done by Lowrance.It demonstrates how an air foil develops at speed with an unprotected sonar mount, causing a loss of sonar readings.
It was very tuff to find a protected mount spot on my FSH210.
But, I did find this location:
You can see how well it is tucked in.
I used a Nano tape to secure it. Be sure your alignment is set before you secure. It's got a very quick, strong hold. Also leave an exposed extension of the tape. By pulling that the tape reliefs it's strong grip.
You can see the extra extension in this photo:
Here's a screen shot of my sonar at 29.6 mph.
There is an issue though. It's going to require 2 side imaging sonars to see both left and right side views. For now, I've set it up with a reversed left image, because the sonar is also mounted backwards (wire coming out the rear), which is acceptable according to Lowrance. They include options to set it up for reverse mount, and left or right imaging only.
