bgood188
- Canton, OH 44721
- Scarab
- 195 ID
I had originally posted about my first gouge on my new boat at Sick to my stomach - Need guidance and thought I would follow up with the repair process and some photos. So, below is the steps I took with comments.
Thanks @Glassman and others for the coaching and part numbers. In the last photo the gouge is below the "W" in the word Twin. I'm happy with the end results.
1) Clean the scratch/Gouge and remove any loose pieces. Below is what I started with. It's about 2 inch long and .5 to .75 inches in height.
2) Mask off the repair area
3) Sand with 400 Grit to prepare for paste
4) Mix paste according to directions. This stuff is nasty and will get on everything so be careful.
5) I used a putty knife to apply. I left a hump of paste so I could sand down to my liking.
6) Use a hair dryer to move along the process and remove the tape. You will need to let it stand for 4-6 hr’s before it’s hard enough to sand. I left mine overnight. (Pic below is with tape removed and no sanding done.
7) Wet sand. I used 400 grit followed by 800 grit. take your time as this can be a long process if you leave a large hump of paste like I did.
8) High speed buffer used for final gloss. I used rubbing compound and buffer to get the final look below.
