Boat Stuff Gladiator Super Brawler 3-Person Towable Tube
LayneG
Purchased last season from Overtons and only used a handful of times. I'm in the Nashville, TN area, will take $175 shipped to the lower 48. I'll upload a picture when I get home.
From their website:
The exciting Super Brawler towable has two tow points for every kind of riding position from kneeling, to prone, to seated on the comfortable foam seat/kneepad with backrest. Features a heavy-duty, double-stitched, full nylon cover, durable RF-welded K80 PVC bladder, tubular webbing foam-filled handles with EVA knuckle guards, comfortable EVA foam seat and knee pads, a quick-connect tow system, and 2 reinforced tow harnesses. Lightning valve inflates/deflates 57% faster than standard valve systems. 510-lb. capacity. 79" x 78". One-year warranty.
The Lightning Valve is similar to the Boston Valve except that it is attached to the towable, so there are no parts to keep up with or lose. The wider opening inflates and deflates 57% faster than the Boston Valve. An interior flap prevents air from escaping, even if the cap is not in place. Inside diameter of the valve measures 30mm. Overton's recommends purchasing one of our Inflator/Deflator pumps (items #109694, #109532, or #109572) that come with an adapter sized to fit the new Lightning valve.
