Rickey Thomas
- Bayliner
- Other
Hi , my name is Rickey Thomas . I live in the Colorado Rockies . recently bought a bayliner Reflexx jet boat and its got a mercury 90 3 cylinder engine . runs great on the hose . took it to the water and it just seems to just plow thru the water . 10 mph max . doesnt feel like its getting up on plane at all . very weak . almost as if its not reaching the power band of the engine under a load at all . After replacement of the plugs and wires . making sure everything is firing with good spark . complete carb rebuild new lines gaskets . ect . then filled with High Octane from the co op it still ran like sh*t. took back to repair shop . they yanked the impeller and sure enough its been replaced . impeller looks new . the impeller casing is a little rough but still useable . so here is my problem is . I need impellers for the mercury 90 sport jet in pitches from 17 to 19, or even a recommendation of what to use that would give me that extras RPM or something designed for use in high altitudes .?? Im about 6000 ft above sea level. Rifle Colorado where can I find these impellers? thanks for your time , frustrated in Colorado
