blacksapphirez
- Charleston, SC
- SX195
the boat that is...
Long story...
-Multiple times I have seen online that the boat weighs over 3000lbs and with gear, lube, fuel, it would be easily over 3500lbs. Today I found out that is not the case.
-Purchased some new wheels and tires for my upcoming trip. Original was D rated and new one is C rating. I was bit nervous because of the weight of the boat is over 3500lbs (internet told me... lol) each tire would need to bear 1750lbs and the tire was rated for 1480lbs.
-I have recently moved the bow stop to be able to fit in the garage. I felt as if the boat was too far forward compare to the others. I have also switched the bunks so the longer wood is sitting on the front end, and moved front bunk mount a notch higher, in turn moving the bow stop a notch higher also. I found out today I can move the bow stop towards the rear of the trailer by another 3 inches which will help my tongue weight.
-TRUCK & BOAT both were full of gas
-I was charged for 3 separate weigh ins....
now the story on the scale. I found on the web that this is a good practice so I weighed in as instructed...but i realized 2nd weigh was not needed as the scale read each individual axles the first time(spacing worked out)
The difference was only 10lbs. (see 2nd pic)
so my tongue weight was somewhere around 500lbs which i think is bit high so I will move the boat back few inches.
1-All wheels on scale. Truck(2 axles)+Trailer (1axle) TOTAL WEIGHT
2-Truck off scale, Trailer Attached (BOAT + TRAILER - TONGUE)
3- Truck off scale, Trailer with trailer jack lowered (FULL TRAILER+BOAT weight)
1-8760
2-2420
3-2920
Truck - 5840
Boat & Trailer - 2920
Tongue - 500
Weight on Trailer Axle - 2420
Long story...
1-8760
2-2420
3-2920
Truck - 5840
Tongue - 500
