This is a replacement cover for Yamaha part number F2D-U8K1L-00-00 also known as SANAV part number GM-88U.
It is a new design that includes an optional external seal. If you do not wish to use the external seal it is recommended to use silicone caulk to seal between the plastic case sections and around the heads of the screws. It is printed from PETG plastic which should hold up well to sun exposure and resist impact.
Click the green "Buy now" button in the top right hand corner to order.
To order click the "Buy now" button in the top right corner or click on this sentence which will take you to PayPal.
