Greasing a LS2000???
JC6275
Clifton IL.
LS
I'm assuming there are some grease fittings for shaft bearings and such, anyone know where they are located, and what kind of grease should I use?
4x15mph
Downingtown, PA
There is one on the front and rear of the engine crankcase (top). They have rubber nipples over the zerk fitting that you have to remove unless they have already fallen off. The rear greases the intermediate assembly and the front greases the starter. You use marine grease
You do not want to over grease the intermediate assembly since it can force the rubber seal to separate and lead to a leak. I have read that it is better to grease while the assembly is turning which makes sense to me.
JC6275
Clifton IL.
LS
Thanks for the info, I thought there had to be a way to grease the shaft bearings somewhere..
JC6275
Clifton IL.
LS
And yes I'm talking about the impeller shaft!!!! LOL
Jmuir
LS
Im not seeing them, and the pictures in the manual doesnt help, Anyway to upload some pics?n
