Edward
- Dallas, TX
I'm not electrical by nature and could use some assistance. I put on CE smith guide posts and followed the directions. I believe I have good ground as I drilled holes in the trailer frame and sanded down to bare metal for the ground.
The posts light up very dim, but eventually get bright under way but then flicker on/off. The flickering is random, and I can't quite tell but it appears both posts might be flickering at the same time.
What's the best way to troubleshoot this? I have a voltmeter just not sure how to tackle as I'm not experienced enough with electrical wiring on a trailer.
Any advice is greatly appreciated.
Thanks,
Ed
Thanks,
Ed
