sunbyrned
- Louisville, KY
- 242 Limited S E-Series
Wonderful! Thanks!I doubt you will have an issue. I see a lot of cast aluminum with cracks like that. Just don't overtighten those bolts down.
Thank you. I read about this but I’m only seeing how it exposes cracks and nothing about the depth. How will I be able to determine the depth?I would recommend to use a dye penetrant or crack check dye to ensure these are not deep. Just to be in the safe side.
Gotcha! That makes sense.As the other experienced members have mentioned, probably there is nothing to worry about.
For the dye penetrant, in general, deeper cracks will trap more dye than shallow.
Gotcha! I shouldn’t have called it the head. Was just thinking the top. But, I’m not mechanically inclined at all so good to know. Appreciate it!FYI, that is the valve cover and not the engine head. Just to be clear. Only risk you are running with those cracks is oil seepage through the top of the valve cover to atmosphere.
Those bosses hold the coils in place if memory serve me right. There is no imminent danger even if one broke completely off.
As you know I'm local. Let me know if it gets worse and you want me to come look at it. Not sure how much I could help, but it's there if you want it.Gotcha! I shouldn’t have called it the head. Was just thinking the top. But, I’m not mechanically inclined at all so good to know. Appreciate it!
I appreciate that! If you’re ever on the Ohio or Taylorsville Lake, give me a holler.As you know I'm local. Let me know if it gets worse and you want me to come look at it. Not sure how much I could help, but it's there if you want it.
