Has anybody converted thier ballast pump to be a raw water wash down system
kthrash
Madison, MS
I was thinking I could put in a three way valve, and convert my ballast pump to be a raw water wash down system? only question is how well the pump works.. I know I would have to put a 4 way valve where the water comes in and is split to the two bags..
Any ideas or thoughts?
latitudeadjuster
Mineral, Virginia
That's a cool thought. T off the line after the pump, so it closes toward ballast and opens towards nozzle. Could make a line like a quick connect like the flush system.....hmmmmmmmm
latitudeadjuster
Mineral, Virginia
It would have to be a hose without the nozzle or the pressure would blow the line apart also. so a nozzle free flowing maybe.....
latitudeadjuster
Mineral, Virginia
Another problem.....the pumps work off a timer I believe.
Ronnie
SF Bay Area
I tried to use a ballast pump for a portable electric water gun once, It didn't work at all. Just not enough pressure to push the water out with any force. I think the steam was maybe 3 feet long. Switched to a 3 gpm wash down pump from west marine, problem solved with a stream of over 20 feet. The out put on both was the same, part of a garden hose.
kthrash
Madison, MS
What if you t off the inlet line to a dedicated pump before the ballast pump? At least you wouldn't be drilling another hole in the boat...
djsquid
South Jordan, UT
@kthrash I did what you are considering. Here is my thread about it. And it works well, I have a 15ft length of hose that I screw onto the garden hose nipple that i have routed out behind the port seatback on the swimdeck. No new holes to drill. I just reach up behind the seatback and pull the hose end out and screw on the garden hose and hit the ballast pump switch and water flows at about 10 gallons per minute. I just use my thumb to increase the spray pressure for wash down. And I love the side selectable ballast for surfing.
https://jetboaters.net/threads/my-solution-to-ballast-tank-selection.5349/
kthrash
Madison, MS
@djsquid, this is exactly what I was thinking of doing less the removable ballest tanks.. Thanks.
