tdonoughue
- The Woodlands, TX 77381
So, first, if you have changed the plugs then there is no need to do so again. They are fine. I would still pull 3 and see if you have the water/fuel in there. Just to check.
Oil very high is bad. You don't want it getting up onto the air filter (that is, overfilled). If that is just from overfilling, that is bad, but easily fixed with sucking some out (go buy a sucker--do your own oil changes with it and it pays for itself on the first change). Bigger problem is if you bring it down to the right level and then it comes up again. That indicates you have water infiltrating into the oil (thus increasing the volume) and you will also see that tell-tale milky oil. You didn't mention milky oil, so let's hope that is just someone overfilling it (which, btw, has been known to throw oil on the air filter and drop rpms).
Sounds to me like everything you have here is likely manageable. If there is not milky oil, you are probably just overfilled and needed new plugs.
Time to start enjoying a boat!
