Help, need a measurement on 06 AR210
Trevor Shipman
Charlotte, NC
Finally decided on a name for our boat "True Half" won't mean much to you guys and gals but it's perfect. Anywho, I want to put the name on the first white lip above the ladder on th stren. Problem is, I don't know how tall that lip is, I keep the boat at a distant storage unit. Any of you guys have your boat at home mind telling me how tall that space is? I not referring to the taller ledge with the grab handle, I'm referring to the white lip just above the rear ladder. Looks to be about 2"?
Thanks!
It's gonna be REALLY small there! That space above the ladder is probably only going to give you about 1.5" of usable space. Don't forget you want the letters to be somewhat proportionate and visible! "True Half" at 1.5" high will only be about 12" long. I went to the left of the grab rail with 3" tall letters. You've got about 24" of space on the left side of the handle...should be plenty for your name. That's about the same size as your registration numbers BTW.
