CadeCyrus
- Other
- PWC
Okay guys I would really could use some of your alls help. I just purchased a brand new 2023 Yamaha VX CRUISER HO on ( 5/23/23 ) I took it out to the lake yesterday ( 5/24/23 ) I backed it off the trailer into the water and with less than a min of idle time the Check Engine light and Temp light came on and started beeping. I called the dealer on the water they told me to cycle machine 3 times and codes should clear, so I did that lights went off. I then started the machine back up and made it 100 yards or so in the no wake zone and lights came on again. I put the machine back on trailer and visually inspected everything all looked good. I took the machine home hooked it up to water hose let it idle for 5+ mins without any lights coming on. I again visually inspected everything I knew to look at, all looked good. I even pulled jet pump filter thinking something was sucked up inside it was clear. I then took the machine back out to the lake and I made it around 100 yards again at idle and the lights came on again. Has anyone had this happen to them? What’s the fix? I came here first before taking it back to the dealer in hopes of an easy fix. Thanks.
