Help needed connecting an aftermarket amp to the new 2021 yamaha SE boats
lightweight
252SE
guys . I need some help . however I'm in north NJ and I haven't found anyone that is able to help. i will be adding 4 new 8in tower speakers from Skar audio as well as a 4channel 1000w RMS Amp to the stock wet sound system that this boats come with. however the problem i found is that i was not aware that the OEM amp has all plugs or temper proof. is there a way to connect or piggy back from there so i can connect 2 RCAs and a remote wire? I've ran all the ground, positive and all speakers wire already but only thing missing is connecting RCAs' and the remote wire.
is there any adapter that i can buy or anything out there? has anyone experience this? your help is appreciated.
adrianp89
Tampa Bay, FL
252SE
Just tap either the input or outwire of the factory amplifier using speaker wire or 9 wire, then put RCA plugs on the other end of the wire.
lightweight
252SE
Hey Adrian , thanks for the info. would you be able to explain it further . maybe thru messenger or DM?
adrianp89
Tampa Bay, FL
252SE
