Help Running Transducer Cable
nvuocolo
Syracuse, NY
Hello everybody hope all is well.
I am installing a 3-in-1 transducer on my 23 AR 250 using a Stern Saver. As I saw on Captain Leonard's Your Tube Video, I am going to run the wire through the bottom of the swim deck and seal it with a cable clamp.
What is the best way to run the cable from the mechanical access port to the cockpit? I have already run the cable for the HDS 9 Live I installed last year and ran the cable down the Starbird side into the engine compartment and to the battery. I have had no issues whatsoever with that. I planned to run the Transducer cable to the fish finder the same way. I just don't know the best way to run it from the mechanical access into the boat, and I still have the boat winterized, so I can't get to it at the moment. Any help would be greatly appreciated! Thanks.
Don't know that I ran that cable yet, nor on that year, but on mine there is a bundle of wires up above the seats in the gunnel area. I followed the bundle out of the engine compartment on the starboard wires or the port battery cables to find the best way on mine.
Hopefully not too late. I was able to run my transducer cable under the gunnel from the engine compartment up the starboard side to the under dash area out of sight and out of mind. There were a few other wires that had the same route. I removed the tray and cup holders to the right of the drivers seat to make sure it was on the right track. I bought the 10 or 11 foot segmented wire running rod from harbor freight to fish the wire. Under the dash I was able to find an unused power source. I fed the power and screen wires through the gap in the dash on the right side. It ended up being a super clean install. I had the ballast tanks to contend with. You should be able to see it go from the engine compartment to the under seat storage to the cup/tray area and then poke through to the under dash pretty easily.
