Kooblay
2004 ar230
So as indicated by the title, I had a clean out plug blowout. On the water I was unable to seat the plug back into place (no extra water noticed in the engine bay), and I limped the boat back to our slip.
I ended up doing the plug rebuild kit to both plugs and installed ez locks. Come time to start the boat the starboard side won't start. It cranks and sounds fine. I ended up pulling the spark plugs, they looked fine. No water in the cylinders, and replaced with new spark plugs.
I'm by no means a jet boat expert, but any tips or advice is certainly appreciated! Before this the boat ran perfectly fine ?
Thank you!!
Thank you!!
