Help troubleshooting engine / throttle issue
Mike Carter
SO. CAL
Good morning every one. I have been working on my boat ( 07 AR-230 ) getting her ready for the season. New plugs are properly gapped and in place. oil & filter are done. Inserted my batteries and checked the switches, stereo, lights, bildge... All good. Started boat with 1/2 a tank of fuel. Boat starts just fine. Idle's just fine no problems.
The prblem is when I move the levers for both engines, they bogg out a little like they want to die. But then they catch up and go in to a medium to high idle. The engines just dont react to the throttle levers as they should. In the past when I moved the levers, the engine responded crisply and with no bogging or hesitation.
I am thinking, I either have bad gas. My thottle boddies need to be cleaned and serviced since it's both sides. Or my injectors are dirty and need to be replaced.
Has anyone had this problem. Some advice would be greatly appreiciated. Thanks for taking the time to read this and Thanks in advance if you respond.
Happy boating my peeps. Mike
Throw a can of seafoam in and then fill it up, then run it and see how it does. Being there’s only a half tank there could’ve been some moisture formed if you just now prepared it for the season. Also idk if you fog the cylinders and intake but if you do you should run the boat for a bit on the hose (preferably on old plugs before changed to new) to burn off all that fogging oil.
Does it happen with both engines? Any excessive gas smell from the exhaust?
How are the air filters? Any oil on them?
If they are not oily I would think it has something to do with fuel quality or delivery.
You could try running without air filters to see if they are the issue.
