road ranger
- Sugar Sand
- Tango
I Just purchased a 98 Sugar Sand Tango with a Mercury 175 V6. I can start it if I prime it well. I can keep it running as long as I pump the primer bulb just before it dies to pressure up the fuel line with fuel. It will only continue to run if I squeeze the primer bulb. I replaced the fuel pump, fuel/water filters, cleared all fuel lines and the issue is still the same.
Does anyone recognize this issue? Can anyone point me in a direction to fix this problem?
Thanks,
Wannbeonthewater
Thanks,
Wannbeonthewater
