help with measuring for a drveshaft
bbar
Hi, 2001 Nautica rib jet 10. Yamaha driveline. 701 motor and 67 E midshaft. I am missing most of the pump. Am told it is a stock yamaha 144 mm pump (possibly a 63E?). Only have the tunnel piece on the outside. Can get the pump parts but am told that there can be several different driveshaft lengths. Only other points of reference I have is the 4 holes in the hull where the parts of the pump bolt up.
How do I measure for a driveshaft?
I tried some rough measuring from inside the midshaft at the splines back to the first set of holes in the hull. I get 27 3/4 ". Is there any stock length yamaha shaft close to that? Thanks
