TommyG
- Carrollton TX
- SX
I have a 2019 242X. I noticed that when I start one engine and the other one is not running yet the bucket on the operating engine does not activate. Meaning neutral gives you idle forward (Not idle) thrust and reverse gives you more forward thrust. Once I start the other engine they both work correctly. I’m pretty sure this is a malfunction that I need to take in but I wanted To get some input from the forum.
