Rushfan67
- Raleigh, NC
- Other
- 222S
Hey Everyone... need some help please.
On Saturday while coming back to the marina as I came off plane I noticed the bilge kick on and dump maybe a 1/2 to a gallon or so of water out. What made it strange is the in the year and half of owning the boat I do t recall this ever happening. So it’s been driving me nuts thinking about it and trying to figure out what’s going on. I read all the threads here on the board of what it might be.
Well today I went to the marina and asked them to take it off the rack so I could at least look at the hull and inspect for damage. After a thorough inspection no damage at all. Next he put it on a work rack for me and I fired it up. No water coming from anywhere. I kicked on the bilge for the heck of it and sure enough about another 1/2 to 1 gallon of water. Let it run and watched the bilge in front of the motor... no water.
I then took off the clean out cover to the right of the clean out plug and it was very wet in there... I have never see it wet in that area. So in looking around I found this and also the silicone basically missing in this spot. Could the water be coming in there? Also on the white nut.. it’s the same size but that is around the inlet to hook the hose to for rinsing out the motor. Last thing.. should the drain near the bilge be open or closed? Any help would be greatly appreciated. Thanks!
