Elio195HOI
- Miramar, Florida
- X
- Other
Picked the boat up from storage, Didn't want to turn over at all. Seemed it was stuck in out of neutral position. I played with the throttle shifting back and forth and it finally turned over. Do we have a neutral safety switch? Ran pretty good until it was time to leave the reef, Engine started rough and Codes PO300, PO301 and PO303 came up with check engine light. Made it back and pulled it out. After washing it down and re parking, realized the Bilge was continuously running and the switch wouldn't turn off, Even with the battery turned to off. Cycled the switch on and off then started the boat, Light on switch finally went out and turned off. Guess its time to make a trip to MM and not see the boat for 3 months....
