Hi group, I need advise for replacement Bimini top for 2008 212x and transom Sony radio module
Fourjets
wilmington N.C. 28412
PWC
I need a new Bimini for the boat. Anyone have one for sale or where I can have one made?
also need the Sony transom module replaced.
starboard reverse gate is very stiff, any Suggestions? I will likely replace the cable but is there somewhere to lubricant the cable?other than right in front of the bucket. I assume there is corrosion throughout the cable.
thanks in advance for any advise from the group. happy Turkeyday!
Babin Farms
Lower Alabama
For the bimini I would just have a local upholstery shop make you a new one. For the gate I would disconnect the cable at the gate to see if it's the cable that needs replaced or if the gate mechanism possibly got bent and replace parts as needed.
Seadeals
Greenville, South Carolina
I second the local upholstery shop. I simply unscrewed the pole(s) to thread it off and they made a new one directly from that “pattern”. The Sunbrella looks way better than the original.
