Hold off on hardtop till I find out what they will do with this.
Floridaman79
Brevard County Florida
FSH Deluxe
Looking at your Lowrance, I want to install the Elite 12 Ti2. Is there enough room?
I think so but can't say for sure. My unit came with templates for the 12 but I threw it away so I wouldn't accidentally use it! You could probably download and print the template or at least get your hands on one and you'd be able to tell.
John_D
Sebastian, FL
FSH Deluxe
I stand corrected, after looking at the top with the stress cracks it is also a flat stock.. My bad......
John_D
Sebastian, FL
FSH Deluxe
Did you run a transponder cable? If so do you have photos of the transom and how you ran the cable to the console. Thanks
Georgetown, IN
I have the same top. I'm thinking of adding diagonal bracing wires like flying wires. I don't think the cracks were caused by a manufacturing flaw as much of a design flaw. The cross section of the tower has a low area moment of inertia athwartship, meaning it doesn't have a lot of stiffness side to side. Side to side movement would definitely cause stress in the location of the cracks.. I've considered a few options to stiffen it up but think the cables attached with turnbuckle would be cheap and effective.
You're correct, the AMOI is low in that direction. In the case of lateral sway, the legs of the tower are far more flexible than the upper assembly, and I would expect them to deflect more than the hartop assembly. This however would lead to a dynamic misalignment between the legs of the tower and the top assembly. You also have that weld in a place of very high stress do to the combination of forces all residing at the same point.
I don't think adding stiffness is the answer here, personally. You will simply move the area of high stress from that joint to elsewhere in the system (most likely the base mounts between the tower and the fiberglass).
Instead I would place a thick (1/4in+) rubber gasket between the hardtop and the tower legs. This will allow both static and dynamic misalignment without significantly decreasing overall system stiffness and deflections, which should hopefully allow for the movement without transferring stress. This assumes the overall deflection doesn't cause problems elsewhere (like the tower legs hitting the fiberglass console).
If you're dead set on adding stiffness to the entire system, then I would suggest adding gussets between the hardtop mounting plates and the cross tubes. This will transfer the lateral deflection loads directly from the mounting plates to the cross braces without putting a weld in the load path. You could also lower that cross brace tube to tie it directly into the lower mounting plate to remove the moment in that welded joint. Another option is to move away from the tube in general, and place a formed channel in that area. It would allow it to be fully welded on both sides of the material (Doubling weld capacity without adding extra passes), and shaped to create a higher stiffness.
Lots of possible re-design solutions here. The "fix" solution is to remove, grind out the weld, and repair at some level. Assuming it's aluminum here, so back purging can help maintain the weld integrity, as well as proper beveling and grinding prep to achieve a full penetration weld from a single side with back purge. Depending on who is in control of the repair I would consider adding some gussets while it's in the fab shop. They are inexpensive and should be effective.
Floridaman79
FSH Deluxe
Here is how I ran the transducer cable. I don't have any pictures of the cable routing but it was a straightforward proposition to run it. I wired it to an accessory switch and swapped out the 10 amp breaker with a 3 amp. If i had life to do over again I don't think I'd wire it to the rocker switch. The reason I put the bulkhead there is that its above the waterline there but also good visibility on the backside so it is easy to service in case it ever leaks.
mkbcaptain
East NC, Surf City.
Does that location work at Speed?
mine is in the same area and doesn’t work past no wake speeds.
John_D
Sebastian, FL
FSH Deluxe
What is the name of the plate covering the cable going through the transom? Thanks for your help, I plan on running this myself so any tips you may have would be appreciated :cool:
Floridaman79
FSH Deluxe
Here is what I used. I had to file down the nubs on the transducer connector and open up the minor thread diameter on the nut by about .010" but other than that it worked out great. Installed with generous amounts of 5200.
Floridaman79
FSH Deluxe
Works great at speed. Reverse washes it out and at idle speeds I get some noise on sonar in the water column but can still see bottom. Really shallow water seems to confuse the unit sometimes.
Tailwaters
St Joseph MI
My transducer is in the same location but opposite side and seems to work just fine at speed
Georgetown, IN
That round tube to flat bar weld is terrible. It's a REALLY REALLY poor design. We avoid those like the plague because they are very difficult to get right, and in a high stress application they fail often.
Some formed or machined saddles would great a MUCH better design in this area, and not add significant cost.
brian86992
Houston, TX
I've thought about this quite a bit. Also considered guy wires or even a welded lateral brace. Like you mentioned, lots of considerations to get a good weld plus matching factory powder coat is a pain.
Guy wires from a thin cable that provides some elasticity might be a good answer. Allowing slight deflection to not over stiffen and over stress the mounting points while limiting deflection magnitude up top. Plus, they can be attached by drilling a hole and not worrying about welding and powder coat.
JetBoatPilot
Event Sponsor
Event Sponsor
Panama City, Fl
I have not seen this personally but I know the manufacturer and he always stands behind his products. Did this get resolved?
