WREKS
- Port Saint Lucie, Florida
- SX
We will start out with Prevention. Do not assume that you can run your engine(s) in shallow water without repercussions!
So you get an overheat warning. What do you do? You may ask yourself. Where have I just been?
I started out with prevention, because I have had many overheat warnings and most of them trace back to running in the shallows and close to sandbars. The pumps swirl up the sand/sediment and push it into the cooling system. But does it all flush out? That is not to say, ingesting sand/sediment is the only cause of overheating. Anything that blocks the flow of water through the system will hopefully shut down the engine in peril. Most of the comments made in this thread regarding overheating issues focus on the cooling system.
I always flushed the engines after being on the water. The boaters that get out there and run those engines at WOT are probably going to fare much better than this old guy that that derived the most pleasure at no-wake speed constantly hearing the depth sounder alarm. One problem I find is that water often goes from deep to shallow quickly. If you spend most of the time in 5 or 6 feet, you may avoid the overheats. When you are pulling up to a sandbar, keep three feet of water under the pump.
Of course being in shallow water also means weeds and debris. Any thing blocking the flow of cooling water is the start of an overheat. If the impeller gets stuffed it loads up the engine. If the intake screen gets blocked, game over. If the flashing on an intake hose breaks off and blocks flow to the cylinder head water jackets, engine will overheat.
My unsubstantiated advice to someone that may have ingested sand/sediment from grounding out is: if the engine has cooled down and the overheat warning is gone, find some deep water and run the engine(s) at higher rpm and hopefully the higher pressure cooling water will start to dislodge some of the ingested sand/sediment. If you are still overheating, the cooling system may have to be cleaned out
I think what happened with my boat is that I thought the flushing would take care of the overheat issue. Maybe sometimes it will, but I ended up with an accumulation of sand/sediment, not salt, in the cylinder water-jackets. It became impacted It had to be scraped and chiseled out. It took hours to do this after removing the cylinder head which required removing the engine from the boat.
What I scraped and chiseled out is below the crusty buildup plainly visible in the first photo. Along with ingesting sand, anything that is smaller than the intake screen will come in. The first photo below is the cylinder block.
The second photo is the cylinder head. It too has plugged up water jackets on the exhaust side. It gets plugged with whatever made it past the intake screen. Again, this occurred on engines that were flushed after use.
Looking at the large water passages in the cylinder head and cylinder block one might ask why this buildup could accumulate although the engines were flushed?
Answer is the head gasket. It does not have the large openings that the cylinder head and the cylinder cylinder block have. I do not know why it is made that way. It blocks flow. It blocks flushing. There is a buildup of sediment/substance on both sides of the gasket. Maybe the cooling system would be even less effective if the gasket was made differently.
The conditions mentioned above are mostly about prevention. The cooling system may very well tolerate quite a bit of buildup of sand/sediment before the overheat light shut down the engines. Flushing is definitely helpful, but not the complete remedy. When the cooling system gets impacted to the extent that mine did on both engines, the only remedy became removing the cylinder head and cleaning the sand/sediment out of the water passages. That requires removing the engine(s) from the boat. That is very expensive. That can easily happen. Please respond with your experiences!
One more photo: The cooling passages of the oil cooler before cleaning.
