How do I remove the captains chair?
Christopher Dobrosky
How do I remove the captains chair? I’m trying to pop the captains chairs off to install sea deck and I can’t get the son of a guns off. I’ve unscrewed the bolt that holds them in and trying to lift it off the pin but no luck. Is there a trick to this? By the way it’s a 2018 SX 195.
Thanks in advance!
Turn the chair half way between click points and with everything lose it will come off.
Ok, so unscrew the black knob underneath, then turn the “triangular” (The rotate/slide adjustment handle) clockwise then lift. If you do it right, it’ll pop right off.
