vxooxv
- Harrisonburg, VA
- SX
Have an Aerial tower. Now that the 650- RGB's are about to arrive for the twin bullets what the heck is the best way to get yet another set of wires down?? The installed harness has 8 wires which are all being used by the 4 speakers.
Install an identicle harness on the opposite side?
Since I believe I can hook all the RGB wires together inside the tower... Maybe - all I really think I need is essentially 1 sheilded wire so I was thinking of trying to drill holes much like the existing harness close to the existing holes maybe and use a rubber grommet of sorts I can plug the drilled hole and feed the smaller wire through??
Between the battery relocation,switch,
ACR, 3 amps, new speakers I may be in over my head.
