vxooxv
- Harrisonburg, VA
- SX
I have 3 amps. All HT-4s.
One has a constant red light. We will call that amp 1.
Power blocks reads at least 13 volts. Consistent with the other 2. So it's not the main power source. Connected to incoming ground just to make sure.
I took the power block out of amp 1 that brings in pos and neg and put in amp 2. Blue light - all good.
I then took out both channel blocks where 1 includes REM and put in amp 2. Blue light. All good.
Both fuses on amp 1 also are good.
I disconnected RCA inputs on amp 1. Still red.
Powered on / off blah blah blah. Still red.
At lake. No subs. Everything worked last weekend. All I did was turn off the blue seas switch and charge the batteries like I do every weekend.
I ain't got no time for this. Any thoughts?
@Odin
@Odin
