tdonoughue
- The Woodlands, TX 77381
Ok, so learning from the posts here, I decided that I am not happy with the present hiss from my system.
Amp and woofer info is below. I have Polks on all 4 spots in the tub. Stock HU. The 4 RCA outputs of the HU go to the amp; the first pair (front?) go direct to the 1-2 inputs of the amp; the second pair is split to 3-4 and 5-6. Fronts are then wired to 1-2, backs to 3-4, and the sub is on 5-6.
Power is run direct to batteries (basically--via ACR) for the amp with 1 ga wires (though the negative one is not as heavily stranded as the other, which I thought was the issue, but read on); stock power wiring for HU.
I read @David Analog , I believe, counseling to work backward from the source. I muted the HU. Still hiss. I unplugged the HU from the amp. Zero hiss. It all went away. Oddly, it went gradually. Each RCA that I pulled decreased it more and more until when I removed the last one it was silent. I believe that eliminates the power to the amp (or basically anything else about the amp) as the issue.
Problem is that I think now this tells me my HU is the issue. Anything that can be done about that? I mean other than throwing out the @#$^ and getting a new quality HU? Or am I missing a step or something simple here?
Thanks in advance for any advice.
