robert843
- Myrtle Beach, SC
So I wanted to put a feeler out to see if there is any interest I have a 6000# (at least that's what I was told) Hydrohoist side tie model b lift possibly for sale as I think I'm going to move up to a Harborhoist. This unit floats and the controls and air pumps all work. The metal brackets will require a some work as I noticed they are starting to show signs of corrosion. Basic work That would need to be completed by purchaser would be two new side bars to attach to dock and new clamps around the floats to hold the bunks to the floats the rest could probably be worked with but maybe worth replacing the bunk set up as well. The good news is this is cheap $1500 and it is yours so even if you repaced all the metal work you would have a great lift system cheap. You would have to transport form Myrtle Beach to your location and you would be responsible for removing it from its current location as well. I will try and get some pics up shortly.
