I am planning on pulling my 175 Sportjet Pump any tips would be appreciated.
Stevenp63
I am planning on pulling my 175 Sportjet Jump I pulled Engine and trying drop pump but top plate won't come off any tips would be appreciated.
I am about to try the same. Did you get her done?
I can’t get it to separate using a flywheel and lift.
I am literally in same boat, and can't get it to separate using flywheel and lift, front end lifts a few mils, rear has zero budge. I saw in other forum the right rear side was stuck and needed wedge to separate then she came right up.
When I did mine I left all the bolts on but loosened them all so I had about 1/16" clearance under the nuts, put a fair amount of pressure on the lift, tapped with a hammer all around then got 4 thin precision welding wedges and started driving them in.
It finally popped loose but it took some doing. I don't think there is any 'magic' way to do it.
