I'm finally a man! I pulled a pump!
I used locktite 567 on my impeller threads. I ordered it from Amazon.
@bronze_10. It would appear that you may have sucked up a small pine branch causing the impeller nick and the debris you found. I've been able to file those out if not too severe. With regard to reinstalling your pumps the pump bolts should be reinstalled with Loctite 567 thread sealer as @Paulie suggested.
Can anyone give me the exact moly grease they use on the splines? There is a lot of choices out there ehen you sestch moly grease!
I used Honda Moly grease as it was said to contain a high percentage of Moly. The more I pull the pumps the less that I believe that the type of grease matters.
