Trm1765
- Red Wing MN
- Limited
I finally put the boat in the water today after installing new impellers. Each motor sounds normal when running individually, but when both engines are started it vibrates and makes bad noise just like when not in the water. (I was in the water)
I am wondering if I got impellers on wrong side? Or maybe wrong impellers? I can't figure out why they wouldn't run good when both running but do run normal individually??
